Einleitung
This guide will provide steps to replace the hard drive of a Acer Aspire E1-532-2616.
Was du brauchst
Use a Phillips screwdriver to remove the CM2.5*3 screw on the shown cover.
Lift and remove the cover from the side that had the holdinging screw.
Push the hard drive away from where the screws were (to the left, if referring to the picture).
The hard drive will slide to the left, allowing it to be safely removed.
Ein Kommentar
Hello! Is it possible to recover data from it? My laptop is dead and I don't know how I could recover my files.. I'm not good in computers :D thank you in advance!
