Einleitung
The keyboard and touchpad are the main input devices in the Acer Aspire E1-572-6829 laptop. If these devices are malfunctioning and none of the steps listed in our troubleshooting guide helps you fix it, you might have to replace these components.
The keyboard and touchpad assembly in this laptop consists of the entire top panel that needs to come off before you can access the motherboard and other internal components of the laptop. This guide will help guide through the steps required to disassemble and replace the top panel assembly in the Acer Aspire E1-572-6829.
Make sure that your device is powered off and the charger is unplugged before beginning the steps in this guide.
Was du brauchst
Flip the laptop over so that you are facing the back panel.
Locate the battery lock switch below the battery.
Slide the battery lock switch to the open position using your finger or a plastic spudger.
While holding this switch open, use your other hand to slide the battery out from the back of the laptop.
Your battery is removed. You can now let go of the lock switch.
Use a Phillips #0 screwdriver to remove the seventeen 8 mm screws that secure the back panel.
Use a plastic spudger to pry open the lower back panel from its top edge.
Lift the panel up and out to remove it.
Use a Phillips #0 screwdriver to remove the three 8 mm screws on the inner side of the lower back panel.
Use the pull tab on the left side of the 2.5 inch hard disk tray to slide it out of the SATA port.
Flip the laptop over and open the lid so that the keyboard side is facing upwards.
Use a plastic pry tool to pry open the tabs holding the top panel on around all sides of the laptop.
Once all the tabs are free, carefully lift up the top panel to open it slightly.
Carefully detach the 3 ribbon cables connecting the top panel to the motherboard.
Once the ribbon cables are detached, the entire top panel consisting of the keyboard and the touch-pad assembly can safely be removed from the laptop.
