Einleitung
After determining that your laptop's battery needs to be replaced, follow this replacement guide to remove your old battery and put in a new one.
Was du brauchst
Remove the 13 indicated screws (6.2 mm) using a Phillips #1 screwdriver.
Insert your plastic opening tool between the bottom case and the rest of the laptop.
Using the plastic opening tool as a lever, apply downward pressure on the tool to lift the bottom up.
Make your way around the case with the tool, every so often applying downward pressure to lift the bottom up.
Lift the bottom off the laptop.
In diesem Schritt verwendetes Werkzeug:Anti-Static Wrist Strap$7.95
Press and hold the battery discharge button on the motherboard for 5 seconds to drain the battery.
Dislodge the battery's connector to the motherboard by using the plastic opening tool as a lever on the two small plastic tabs that stick out on either side of the connector.
Unscrew the two 6.2 mm Phillips #1 head screws on either side of the battery as indicated.
