Zum Hauptinhalt wechseln
Acer Aspire E3-111-C0WA Hard Drive Replacement
Was du brauchst
  1. Acer Aspire E3-111-C0WA Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 2 Acer Aspire E3-111-C0WA Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the 13 indicated screws (6.2 mm) using a Phillips #1 screwdriver.
  2. Acer Aspire E3-111-C0WA Hard Drive Replacement: Schritt 2, Bild 1 von 3 Acer Aspire E3-111-C0WA Hard Drive Replacement: Schritt 2, Bild 2 von 3 Acer Aspire E3-111-C0WA Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Insert your plastic opening tool between the bottom case and the rest of the laptop.
    • Using the plastic opening tool as a lever, apply downward pressure on the tool to lift the bottom up.
    • Make your way around the case with the tool, every so often applying downward pressure to lift the bottom up.
    • Lift the bottom off the laptop.
  3. Acer Aspire E3-111-C0WA Hard Drive Replacement: Schritt 3, Bild 1 von 2 Acer Aspire E3-111-C0WA Hard Drive Replacement: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Anti-Static Wrist Strap
    $7.95
    Kaufen
    • Make sure you have properly grounded yourself to avoid potentially damaging any internal components by wearing the anti-static wrist strap and attaching the clip end to metal.
    • Press and hold the battery discharge button on the motherboard for 5 seconds to drain the battery.
  4. Acer Aspire E3-111-C0WA Hard Drive Replacement: Schritt 4, Bild 1 von 3 Acer Aspire E3-111-C0WA Hard Drive Replacement: Schritt 4, Bild 2 von 3 Acer Aspire E3-111-C0WA Hard Drive Replacement: Schritt 4, Bild 3 von 3
    • Dislodge the battery's connector to the motherboard by using the plastic opening tool as a lever on the two small plastic tabs that stick out on either side of the connector.
  5. Acer Aspire E3-111-C0WA Hard Drive Replacement: Schritt 5, Bild 1 von 2 Acer Aspire E3-111-C0WA Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Unscrew the two 6.2 mm Phillips #1 head screws on either side of the battery as indicated.
  6. Acer Aspire E3-111-C0WA Hard Drive Replacement: Schritt 6, Bild 1 von 2 Acer Aspire E3-111-C0WA Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Lift the battery up and off the rest of the laptop.
  7. Acer Aspire E3-111-C0WA Hard Drive Replacement, Hard Drive: Schritt 7, Bild 1 von 2 Acer Aspire E3-111-C0WA Hard Drive Replacement, Hard Drive: Schritt 7, Bild 2 von 2
    • Holding the laptop in place, slide the hard drive horizontally out from the SATA connector.
Abschluss
UC Santa Barbara, Team S1-G2, Weedon Fall 2017 Mitglied von UC Santa Barbara, Team S1-G2, Weedon Fall 2017
UCSB-WEEDON-F17S1G2
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 607
