Einleitung
Should you wish to replace or upgrade the memory in your laptop, this guide will show you how to access and remove your old RAM.
Was du brauchst
Remove the 13 indicated screws (6.2 mm) using a Phillips #1 screwdriver.
Insert your plastic opening tool between the bottom case and the rest of the laptop.
Using the plastic opening tool as a lever, apply downward pressure on the tool to lift the bottom up.
Make your way around the case with the tool, every so often applying downward pressure to lift the bottom up.
Lift the bottom off the laptop.
In diesem Schritt verwendetes Werkzeug:Anti-Static Wrist Strap$7.95
Press and hold the battery discharge button on the motherboard for 5 seconds to drain the battery.
Dislodge the battery's connector to the motherboard by using the plastic opening tool as a lever on the two small plastic tabs that stick out on either side of the connector.
Unscrew the two 6.2 mm Phillips #1 head screws on either side of the battery as indicated.
Remove the two antenna cables from the wireless card. These should snap lightly out of place when lifted upwards.
Remove the 6.2mm #1 Phillips head screw attaching the wireless card to the case.
Pull the wireless card horizontally away from the motherboard to remove it from the connector.
Holding the laptop in place, slide the hard drive horizontally out from the SATA connector.
Lightly pry upwards on the black plastic tab to release the touchpad cable, then gently pull the cable from the connector.
Find the keyboard cable. Pull the two gray plastic tabs outwards to release the ribbon. Gently pull the cable from the connector.
Pull down gently on the black speaker cable connector to disconnect it from the motherboard.
Peel up the tape adhering the display cable to the connector on the motherboard.
Slide the display cable horizontally out of the connector to remove it from the motherboard.
Unscrew the four 6.2mm Phillips #1 screws attaching the motherboard to the case.
With all the screws and cables detached, lift the motherboard directly upwards out of the case.
Flip over the motherboard after removing it from the case.
Apply pressure outward on the metal tabs on either side of the RAM stick to release them from the notches on the stick.
After the tabs have been released, slide the RAM out of the slot.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Thank you for this very well done step by step guide! I updated the RAM in this computer with no issues because of your procedure. FYI - I am a fellow Gaucho graduate way back from the Class of 1981.
