Einleitung
If your wireless card needs replacement, follow the steps in this guide to remove it.
Was du brauchst
Remove the 13 indicated screws (6.2 mm) using a Phillips #1 screwdriver.
Insert your plastic opening tool between the bottom case and the rest of the laptop.
Using the plastic opening tool as a lever, apply downward pressure on the tool to lift the bottom up.
Make your way around the case with the tool, every so often applying downward pressure to lift the bottom up.
Lift the bottom off the laptop.
Press and hold the battery discharge button on the motherboard for 5 seconds to drain the battery.
Dislodge the battery's connector to the motherboard by using the plastic opening tool as a lever on the two small plastic tabs that stick out on either side of the connector.
Unscrew the two 6.2 mm Phillips #1 head screws on either side of the battery as indicated.
Remove the two antenna cables from the wireless card. These should snap lightly out of place when lifted upwards.
Remove the 6.2mm #1 Phillips head screw attaching the wireless card to the case.
Pull the wireless card horizontally away from the motherboard to remove it from the connector.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
