Zum Hauptinhalt wechseln
Acer Aspire E5-471-5456 Back Replacement
Was du brauchst
  1. Acer Aspire E5-471-5456 Back Replacement, Back Cover: Schritt 1, Bild 1 von 2 Acer Aspire E5-471-5456 Back Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Carefully place the closed computer on a flat surface, with it oriented screen down.
    • Now you need to use the Phillips #0 Screwdriver to remove all 17 of the M2.5X8 mm screws. Use the red circles on the diagram to help you locate these screws.
  2. Acer Aspire E5-471-5456 Back Replacement: Schritt 2, Bild 1 von 2 Acer Aspire E5-471-5456 Back Replacement: Schritt 2, Bild 2 von 2
    • Use an opening tool to gently pry open the case.
    • Take extreme care when removing the case to not get the case stuck on any of the ports. Make sure that to evenly open the case and not pry one side open before the other to avoid damage.
    • Slowly peel the cover off and make sure there are no wires or clips still connecting the two pieces together. These pieces are extremely fragile so it is vital to take your time and only use light pressure.
  3. Acer Aspire E5-471-5456 Back Replacement: Schritt 3, Bild 1 von 1
    • Place cover and screws aside and you are now free to access the different components of this laptop.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team S6-G4, Banghart Fall 2017 Mitglied von Cal Poly, Team S6-G4, Banghart Fall 2017
CPSU-BANGHART-F17S6G4
5 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
Thank You for the information!
jeanie49 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 14
Insgesamt: 1,397
