Zum Hauptinhalt wechseln
Acer Aspire E5-471-5456 Hard Drive Replacement
Was du brauchst
  1. Acer Aspire E5-471-5456 Hard Drive Replacement, Back Cover: Schritt 1, Bild 1 von 2 Acer Aspire E5-471-5456 Hard Drive Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Carefully place the closed computer on a flat surface, with it oriented screen down.
    • Now you need to use the Phillips #0 Screwdriver to remove all 17 of the M2.5X8 mm screws. Use the red circles on the diagram to help you locate these screws.
  2. Acer Aspire E5-471-5456 Hard Drive Replacement: Schritt 2, Bild 1 von 2 Acer Aspire E5-471-5456 Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Use an opening tool to gently pry open the case.
    • Take extreme care when removing the case to not get the case stuck on any of the ports. Make sure that to evenly open the case and not pry one side open before the other to avoid damage.
    • Slowly peel the cover off and make sure there are no wires or clips still connecting the two pieces together. These pieces are extremely fragile so it is vital to take your time and only use light pressure.
  3. Acer Aspire E5-471-5456 Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Place cover and screws aside and you are now free to access the different components of this laptop.
  4. Acer Aspire E5-471-5456 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 1
    • Locate the hard drive at the bottom left corner of the laptop. On the silver plate securing the hard drive, remove the four M2X3 mm screws on each corner (refer to the red circles for screw locations).
  5. Acer Aspire E5-471-5456 Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Slowly lift the hard drive with its corresponding securing plates up and out of its housing unplugging it from the motherboard.
  6. Acer Aspire E5-471-5456 Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Once completely removed, separate the hard drive from the securing plates.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team S6-G4, Banghart Fall 2017 Mitglied von Cal Poly, Team S6-G4, Banghart Fall 2017
CPSU-BANGHART-F17S6G4
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 18
Insgesamt: 3,449
