Zum Hauptinhalt wechseln
Acer Aspire E5-471-5456 USB Port Replacement
Was du brauchst
  1. Acer Aspire E5-471-5456 USB Port Replacement, Back Cover: Schritt 1, Bild 1 von 2 Acer Aspire E5-471-5456 USB Port Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Carefully place the closed computer on a flat surface, with it oriented screen down.
    • Now you need to use the Phillips #0 Screwdriver to remove all 17 of the M2.5X8 mm screws. Use the red circles on the diagram to help you locate these screws.
  2. Acer Aspire E5-471-5456 USB Port Replacement: Schritt 2, Bild 1 von 2 Acer Aspire E5-471-5456 USB Port Replacement: Schritt 2, Bild 2 von 2
    • Use an opening tool to gently pry open the case.
    • Take extreme care when removing the case to not get the case stuck on any of the ports. Make sure that to evenly open the case and not pry one side open before the other to avoid damage.
    • Slowly peel the cover off and make sure there are no wires or clips still connecting the two pieces together. These pieces are extremely fragile so it is vital to take your time and only use light pressure.
  3. Acer Aspire E5-471-5456 USB Port Replacement: Schritt 3, Bild 1 von 1
    • Place cover and screws aside and you are now free to access the different components of this laptop.
  4. Acer Aspire E5-471-5456 USB Port Replacement, USB Port: Schritt 4, Bild 1 von 2 Acer Aspire E5-471-5456 USB Port Replacement, USB Port: Schritt 4, Bild 2 von 2
    • Locate the two USB ports in the bottom corner of the laptop.
    • Use a screwdriver to take out the M2X3 mm screw located in the orange circle. For an easier reassembly, take note that the USB port has a white arrow that indicates which  orange hole the screw should be returned to.
  5. Acer Aspire E5-471-5456 USB Port Replacement: Schritt 5, Bild 1 von 2 Acer Aspire E5-471-5456 USB Port Replacement: Schritt 5, Bild 2 von 2
    • Remove the cable (look for the one with a blue tag reading "USB") very carefully as it is fragile by using the opening tool.
  6. Acer Aspire E5-471-5456 USB Port Replacement: Schritt 6, Bild 1 von 1
    • The USB ports should now be able to be removed from the laptop, carefully.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team S6-G4, Banghart Fall 2017 Mitglied von Cal Poly, Team S6-G4, Banghart Fall 2017
CPSU-BANGHART-F17S6G4
5 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
where can i purchase the port
Jermian Francis - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 20
Insgesamt: 1,946
