Zum Hauptinhalt wechseln
Acer Aspire E5-571 Battery Replacement
Was du brauchst
  1. Acer Aspire E5-571 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure the laptop is shut down.
    • Flip the laptop upside down. Rotate it so the battery faces you.
  2. Acer Aspire E5-571 Battery Replacement: Schritt 2, Bild 1 von 1
    • Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
  3. Acer Aspire E5-571 Battery Replacement: Schritt 3, Bild 1 von 1
    • Pull the battery towards you to remove it from the laptop.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
daniel sawyer
2.566 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 4-2, Meier Fall 2015 Mitglied von USF Tampa, Team 4-2, Meier Fall 2015
USFT-MEIER-F15S4G2
3 Mitglieder
2 Kommentare
Uh…this makes no mention of the keyboard. Why is this titled as a keyboard repair, when it simply removes the battery?
David Greene - Antwort
lets hope next time the “This guide is being worked on by hardworking students. “ the steps involve more then just removing the battery
mechanimal15 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 16
Letzte 30 Tage: 74
Insgesamt: 23,594
