Einleitung
Is your laptop overheating or staying on for a few minutes and then powering itself down? Your CPU Fan may be to blame. This guide will show you how to replace it.
Was du brauchst
Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
Carefully pry apart the clips holding the keyboard in place by moving a metal spudger along the seam.
Carefully flip up the white hinge. Then, detach the three ZIF ribbons connected to the motherboard.
Remove the panel with the keyboard and the touchpad.
Locate the two antenna cables shown.
Using a plastic opening tool, remove both antenna cables from the WiFi card by gently prying them up.
Remove this 3 mm Phillips #0 screw and the WiFi card should pop up.
Gently lift WiFi card off of the motherboard.
Remove both of these 6 mm Phillips #1 screws which hold the fan onto the case.
Now carefully lift the fan straight up and out of its place in the case.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
