Einleitung
If the hard drive has broken or if you are planning on putting in an SSD hard drive, this guide will show you how.
Was du brauchst
Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
Carefully pry apart the clips holding the keyboard in place by moving a metal spudger along the seam.
Carefully flip up the white hinge. Then, detach the three ZIF ribbons connected to the motherboard.
Remove the panel with the keyboard and the touchpad.
Locate this ZIF ribbon and carefully flip the white top hinge up and bend the ribbon over to the right side.
There is one screw on each side of the metal hard drive casing you remove.
Slide the hard drive out of the metal casing.
42 weitere Nutzer:innen haben diese Anleitung absolviert.
8 Kommentare
You can't beat the internet when it comes to sorting out a problem.
Many thanks to the author of this guide, it really helped me out
These are excellent clear instructions, well done and thank you
Great directions. With visual ades too...nice.
Thanks
Thank you for the clear instructions, this is an excellent guide.
Very helpful guide. Thanks for that! Only thing missing was a warning about where the plastic clips were around the body to make it easier to pop those without breaking the plastic tabs on some of them. Even that isn’t all that important really.
