Zum Hauptinhalt wechseln
Acer Aspire E5-571-58CG CPU Fan Replacement
Was du brauchst
  1. Acer Aspire E5-571-58CG CPU Fan Replacement, Battery: Schritt 1, Bild 1 von 2 Acer Aspire E5-571-58CG CPU Fan Replacement, Battery: Schritt 1, Bild 2 von 2
    • Make sure the laptop is powered off.
    • Flip the laptop over and locate the battery release switch.
    • Insert the pointed end of the spudger into the battery release switch.
    • Push the battery release switch to the right.
  2. Acer Aspire E5-571-58CG CPU Fan Replacement: Schritt 2, Bild 1 von 3 Acer Aspire E5-571-58CG CPU Fan Replacement: Schritt 2, Bild 2 von 3 Acer Aspire E5-571-58CG CPU Fan Replacement: Schritt 2, Bild 3 von 3
    • While the battery release switch is pushed to the right, carefully slide the battery out of its socket.
  3. Acer Aspire E5-571-58CG CPU Fan Replacement, CPU Fan: Schritt 3, Bild 1 von 3 Acer Aspire E5-571-58CG CPU Fan Replacement, CPU Fan: Schritt 3, Bild 2 von 3 Acer Aspire E5-571-58CG CPU Fan Replacement, CPU Fan: Schritt 3, Bild 3 von 3
    • Remove the top panel of the laptop with the plastic opening tool.
  4. Acer Aspire E5-571-58CG CPU Fan Replacement: Schritt 4, Bild 1 von 2 Acer Aspire E5-571-58CG CPU Fan Replacement: Schritt 4, Bild 2 von 2
    • Use a JIS #000 screw bit to remove the marked screw.
  5. Acer Aspire E5-571-58CG CPU Fan Replacement: Schritt 5, Bild 1 von 2 Acer Aspire E5-571-58CG CPU Fan Replacement: Schritt 5, Bild 2 von 2
    • Carefully pull the marked green chip out of the motherboard.
  6. Acer Aspire E5-571-58CG CPU Fan Replacement: Schritt 6, Bild 1 von 2 Acer Aspire E5-571-58CG CPU Fan Replacement: Schritt 6, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use tweezers to unplug the wire connecting the fan to the motherboard.
  7. Acer Aspire E5-571-58CG CPU Fan Replacement: Schritt 7, Bild 1 von 3 Acer Aspire E5-571-58CG CPU Fan Replacement: Schritt 7, Bild 2 von 3 Acer Aspire E5-571-58CG CPU Fan Replacement: Schritt 7, Bild 3 von 3
    • Use a JIS #00 screw bit to remove the marked screws around the CPU fan.
    • Carefully remove the CPU fan.
Abschluss
Brendan Cuthill
121 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S7-G7, Valliere Fall 2018 Mitglied von UMass Dartmouth, Team S7-G7, Valliere Fall 2018
UMASSD-VALLIERE-F18S7G7
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 304
