Zum Hauptinhalt wechseln
Acer Aspire E5-571-58CG Keyboard Replacement
Was du brauchst
  1. Acer Aspire E5-571-58CG Keyboard Replacement, Battery: Schritt 1, Bild 1 von 2 Acer Aspire E5-571-58CG Keyboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Make sure the laptop is powered off.
    • Flip the laptop over and locate the battery release switch.
    • Insert the pointed end of the spudger into the battery release switch.
    • Push the battery release switch to the right.
  2. Acer Aspire E5-571-58CG Keyboard Replacement: Schritt 2, Bild 1 von 3 Acer Aspire E5-571-58CG Keyboard Replacement: Schritt 2, Bild 2 von 3 Acer Aspire E5-571-58CG Keyboard Replacement: Schritt 2, Bild 3 von 3
    • While the battery release switch is pushed to the right, carefully slide the battery out of its socket.
  3. Acer Aspire E5-571-58CG Keyboard Replacement, Keyboard: Schritt 3, Bild 1 von 3 Acer Aspire E5-571-58CG Keyboard Replacement, Keyboard: Schritt 3, Bild 2 von 3 Acer Aspire E5-571-58CG Keyboard Replacement, Keyboard: Schritt 3, Bild 3 von 3
    • Make sure laptop is upright.
    • Pry the keyboard cover off with the plastic opening tool.
  4. Acer Aspire E5-571-58CG Keyboard Replacement: Schritt 4, Bild 1 von 3 Acer Aspire E5-571-58CG Keyboard Replacement: Schritt 4, Bild 2 von 3 Acer Aspire E5-571-58CG Keyboard Replacement: Schritt 4, Bild 3 von 3
    • Flip the keyboard cover upside down.
    • Use the JIS #000 screw bit to remove the marked M1.4 x 2 mm screws from the back of the metal panel.
  5. Acer Aspire E5-571-58CG Keyboard Replacement: Schritt 5, Bild 1 von 3 Acer Aspire E5-571-58CG Keyboard Replacement: Schritt 5, Bild 2 von 3 Acer Aspire E5-571-58CG Keyboard Replacement: Schritt 5, Bild 3 von 3
    • Push the metal panel forward to unlock it from plastic holders on both sides.
    • Lift the metal panel up and peel it back to expose the keyboard component.
  6. Acer Aspire E5-571-58CG Keyboard Replacement: Schritt 6, Bild 1 von 3 Acer Aspire E5-571-58CG Keyboard Replacement: Schritt 6, Bild 2 von 3 Acer Aspire E5-571-58CG Keyboard Replacement: Schritt 6, Bild 3 von 3
    • Use the metal spudger to lift the keyboard component out of the metal panel.
Abschluss
Matthew Barboza
159 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S7-G7, Valliere Fall 2018 Mitglied von UMass Dartmouth, Team S7-G7, Valliere Fall 2018
UMASSD-VALLIERE-F18S7G7
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 459
