Zum Hauptinhalt wechseln
Acer Aspire E5-571-58CG Power Jack Replacement
Was du brauchst
  1. Acer Aspire E5-571-58CG Power Jack Replacement, Battery: Schritt 1, Bild 1 von 2 Acer Aspire E5-571-58CG Power Jack Replacement, Battery: Schritt 1, Bild 2 von 2
    • Make sure the laptop is powered off.
    • Flip the laptop over and locate the battery release switch.
    • Insert the pointed end of the spudger into the battery release switch.
    • Push the battery release switch to the right.
  2. Acer Aspire E5-571-58CG Power Jack Replacement: Schritt 2, Bild 1 von 3 Acer Aspire E5-571-58CG Power Jack Replacement: Schritt 2, Bild 2 von 3 Acer Aspire E5-571-58CG Power Jack Replacement: Schritt 2, Bild 3 von 3
    • While the battery release switch is pushed to the right, carefully slide the battery out of its socket.
  3. Acer Aspire E5-571-58CG Power Jack Replacement, Power Jack: Schritt 3, Bild 1 von 3 Acer Aspire E5-571-58CG Power Jack Replacement, Power Jack: Schritt 3, Bild 2 von 3 Acer Aspire E5-571-58CG Power Jack Replacement, Power Jack: Schritt 3, Bild 3 von 3
    • Remove the top panel of the laptop with the plastic opening tool.
  4. Acer Aspire E5-571-58CG Power Jack Replacement: Schritt 4, Bild 1 von 2 Acer Aspire E5-571-58CG Power Jack Replacement: Schritt 4, Bild 2 von 2
    • Remove the plastic safeguard from the CD drive slot.
  5. Acer Aspire E5-571-58CG Power Jack Replacement: Schritt 5, Bild 1 von 3 Acer Aspire E5-571-58CG Power Jack Replacement: Schritt 5, Bild 2 von 3 Acer Aspire E5-571-58CG Power Jack Replacement: Schritt 5, Bild 3 von 3
    • Remove the marked screws with the JIS #00 screwdriver.
  6. Acer Aspire E5-571-58CG Power Jack Replacement: Schritt 6, Bild 1 von 2 Acer Aspire E5-571-58CG Power Jack Replacement: Schritt 6, Bild 2 von 2
    • Disconnect the opposite end of the power jack from the motherboard by carefully pulling the wire.
  7. Acer Aspire E5-571-58CG Power Jack Replacement: Schritt 7, Bild 1 von 2 Acer Aspire E5-571-58CG Power Jack Replacement: Schritt 7, Bild 2 von 2
    • Lift the bottom right side of the screen to move the metal plate covering the power jack.
  8. Acer Aspire E5-571-58CG Power Jack Replacement: Schritt 8, Bild 1 von 2 Acer Aspire E5-571-58CG Power Jack Replacement: Schritt 8, Bild 2 von 2
    • Carefully lift the power jack out of the laptop.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Aliana Johnson
145 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S7-G7, Valliere Fall 2018 Mitglied von UMass Dartmouth, Team S7-G7, Valliere Fall 2018
UMASSD-VALLIERE-F18S7G7
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 1,258
