Einleitung
A broken touchpad may interfere with your ability to use the laptop, and it may need to be replaced. This guide will help you through this process.
Was du brauchst
Flip the keyboard cover upside down.
Use the JIS #000 screw bit to remove the marked M1.4 x 2 mm screws from the back of the metal panel.
Push the metal panel forward to unlock it from plastic holders on both sides.
Lift the metal panel up and peel it back to expose the keyboard component.
Use a 1 1/2 mm flathead screw bit to remove the black screw at the bottom of the panel.
Use a 1 1/2 mm flathead screw bit to remove the two black screws at the top of the panel.
