Zum Hauptinhalt wechseln
Acer Aspire E5-571P-55TL Hard Drive Replacement
Was du brauchst
  1. Acer Aspire E5-571P-55TL Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure that laptop is turned off.
    • Turn the laptop upside down with the battery facing you.
  2. Acer Aspire E5-571P-55TL Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Place the Spudger into the battery lock and slide it to the left until you hear the battery unlock.
  3. Acer Aspire E5-571P-55TL Hard Drive Replacement: Schritt 3, Bild 1 von 2 Acer Aspire E5-571P-55TL Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Pull the battery towards you to remove it from the laptop.
  4. Acer Aspire E5-571P-55TL Hard Drive Replacement, Keyboard: Schritt 4, Bild 1 von 2 Acer Aspire E5-571P-55TL Hard Drive Replacement, Keyboard: Schritt 4, Bild 2 von 2
    • Using a Phillips #0 screwdriver, remove each of the eighteen 8 mm screws from the bottom of the laptop.
  5. Acer Aspire E5-571P-55TL Hard Drive Replacement: Schritt 5, Bild 1 von 3 Acer Aspire E5-571P-55TL Hard Drive Replacement: Schritt 5, Bild 2 von 3 Acer Aspire E5-571P-55TL Hard Drive Replacement: Schritt 5, Bild 3 von 3
    • Carefully place your fingers underneath the top of the keyboard just below the screen.
    • Pull upwards until you can hear the keyboard click out of place.
    • Continue around the entire laptop, carefully pulling the keyboard and palm rest assembly slightly from the frame to reveal the ribbon connectors.
    • Don't pull the keyboard off the frame yet because it's attached by ribbon connectors.
    • After the keyboard is detached, unplug each of the three ribbon cables and remove the keyboard and palm rest assembly.
  6. Acer Aspire E5-571P-55TL Hard Drive Replacement, Hard Drive: Schritt 6, Bild 1 von 1
    • Using a Phillips #0 screwdriver, remove the two 8 mm screws holding the hard drive carriage in place.
  7. Acer Aspire E5-571P-55TL Hard Drive Replacement: Schritt 7, Bild 1 von 2 Acer Aspire E5-571P-55TL Hard Drive Replacement: Schritt 7, Bild 2 von 2
    • Carefully unplug the ribbon cable running across the hard drive carriage and place it to the side.
    • Remove the hard drive by sliding it to your right, away from the motherboard, next pull the hard drive towards yourself and away from the laptop.
  8. Acer Aspire E5-571P-55TL Hard Drive Replacement: Schritt 8, Bild 1 von 1
    • Once again using a Phillips #0 screwdriver, remove the two 3 mm screws highlighted on each side of the hard drive case.
    • Open the hard drive case to replace the hard drive.
Abschluss
UMass Dartmouth, Team B-1, Gurgel Spring 2022 Mitglied von UMass Dartmouth, Team B-1, Gurgel Spring 2022
UMASSD-GURGEL-S22SBG1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 145
