Zum Hauptinhalt wechseln
Acer Aspire E5-573G Fan Replacement
Was du brauchst
  1. Acer Aspire E5-573G Fan  Replacement, Fan: Schritt 1, Bild 1 von 2 Acer Aspire E5-573G Fan  Replacement, Fan: Schritt 1, Bild 2 von 2
    • Remove the seventeen 5 mm screws from the back cover using a Phillips #00 screwdriver.
    • Be sure to unplug and power down your computer before starting any work.
  2. Acer Aspire E5-573G Fan  Replacement: Schritt 2, Bild 1 von 2 Acer Aspire E5-573G Fan  Replacement: Schritt 2, Bild 2 von 2
    • Remove the CD drive located on the side of the laptop.
  3. Acer Aspire E5-573G Fan  Replacement: Schritt 3, Bild 1 von 1
    • Remove the three 2 mm screws from the disc drive bay using a Phillips #00 screwdriver.
  4. Acer Aspire E5-573G Fan  Replacement: Schritt 4, Bild 1 von 3 Acer Aspire E5-573G Fan  Replacement: Schritt 4, Bild 2 von 3 Acer Aspire E5-573G Fan  Replacement: Schritt 4, Bild 3 von 3
    • Use the spudger to pry open the back cover by sliding it along the sides.
    • Slowly lift the cover upwards.
    • Be gentle while removing the case as it is very thin and might break easily.
  5. Acer Aspire E5-573G Fan  Replacement: Schritt 5, Bild 1 von 2 Acer Aspire E5-573G Fan  Replacement: Schritt 5, Bild 2 von 2
    • Apply canned air or use a bellows to remove the dust on the motherboard.
    • Remove the two 2 mm screws holding the fan to the motherboard using Phillips #00 screwdriver.
    • Be gentle unscrewing both screws as the motherboard can get damaged with extra force.
  6. Acer Aspire E5-573G Fan  Replacement: Schritt 6, Bild 1 von 3 Acer Aspire E5-573G Fan  Replacement: Schritt 6, Bild 2 von 3 Acer Aspire E5-573G Fan  Replacement: Schritt 6, Bild 3 von 3
    • Lift out the fan and detach the fan cable from the motherboard.
    • When detaching the cable be careful not to pull the wires. Instead pull the white section that connects the fan to the motherboard.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Lara Mustafa
133 Reputation
1 Anleitung geschrieben
York University, Team S1-G20, O'Regan Winter 2021 Mitglied von York University, Team S1-G20, O'Regan Winter 2021
YORK-O'REGAN-W21S1G20
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 30
Insgesamt: 842
