Zum Hauptinhalt wechseln
Acer Aspire E5-573G Fan Replacement
Was du brauchst
  1. Acer Aspire E5-573G Fan  Replacement, Fan: Schritt 1, Bild 1 von 2 Acer Aspire E5-573G Fan  Replacement, Fan: Schritt 1, Bild 2 von 2
    • Remove the seventeen 5 mm screws from the back cover using a Phillips #00 screwdriver.
    • Be sure to unplug and power down your computer before starting any work.
    Frag FixBot
  2. Acer Aspire E5-573G Fan  Replacement: Schritt 2, Bild 1 von 2 Acer Aspire E5-573G Fan  Replacement: Schritt 2, Bild 2 von 2
    • Remove the CD drive located on the side of the laptop.
    Frag FixBot
  3. Acer Aspire E5-573G Fan  Replacement: Schritt 3, Bild 1 von 1
    • Remove the three 2 mm screws from the disc drive bay using a Phillips #00 screwdriver.
    Frag FixBot
  4. Acer Aspire E5-573G Fan  Replacement: Schritt 4, Bild 1 von 3 Acer Aspire E5-573G Fan  Replacement: Schritt 4, Bild 2 von 3 Acer Aspire E5-573G Fan  Replacement: Schritt 4, Bild 3 von 3
    • Use the spudger to pry open the back cover by sliding it along the sides.
    • Slowly lift the cover upwards.
    • Be gentle while removing the case as it is very thin and might break easily.
    Frag FixBot
  5. Acer Aspire E5-573G Fan  Replacement: Schritt 5, Bild 1 von 2 Acer Aspire E5-573G Fan  Replacement: Schritt 5, Bild 2 von 2
    • Apply canned air or use a bellows to remove the dust on the motherboard.
    • Remove the two 2 mm screws holding the fan to the motherboard using Phillips #00 screwdriver.
    • Be gentle unscrewing both screws as the motherboard can get damaged with extra force.
    Frag FixBot
  6. Acer Aspire E5-573G Fan  Replacement: Schritt 6, Bild 1 von 3 Acer Aspire E5-573G Fan  Replacement: Schritt 6, Bild 2 von 3 Acer Aspire E5-573G Fan  Replacement: Schritt 6, Bild 3 von 3
    • Lift out the fan and detach the fan cable from the motherboard.
    • When detaching the cable be careful not to pull the wires. Instead pull the white section that connects the fan to the motherboard.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Lara Mustafa
133 Reputation
1 Anleitung geschrieben
York University, Team S1-G20, O'Regan Winter 2021 Mitglied von York University, Team S1-G20, O'Regan Winter 2021
YORK-O'REGAN-W21S1G20
2 Mitglieder
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 21
Letzte 30 Tage: 57
Insgesamt: 1,475
