Was du brauchst
Remove the two 6mm J0 screws located in the right and left side of the battery.
Remove the two 6mm Phillips J0 screws located in the right and left side of heatsink mounts.
Remove the four 6mm Phillips J0 screws located on the heatsink power mount.
Lift and remove heatsink from motherboard completely.
Remove the four blue tabbed ribbon connectors to the motherboard by lifting white clamps and pulling out connector.
Remove black ribbon connector by lifting white clamp and pulling connector out.
Finally lift motherboard from narrow side and jiggle it out so all ports going through the laptop case on the left slide out.
