Zum Hauptinhalt wechseln
Acer Aspire E5-721-64T8 Touch Pad Replacement
Was du brauchst
  1. Acer Aspire E5-721-64T8 Touch Pad Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the twenty-five 6mm Phillips #0 screws from the bottom panel of the laptop.
  2. Acer Aspire E5-721-64T8 Touch Pad Replacement: Schritt 2, Bild 1 von 1
    • Using the plastic opening tool, lift up on the side opposite of the Ethernet connector.
    • With the plastic opening tool under the bottom panel, work your way around the perimeter until the panel separates.
  3. Acer Aspire E5-721-64T8 Touch Pad Replacement: Schritt 3, Bild 1 von 1
    • Remove the two 6mm Phillips #0 screws from the battery.
  4. Acer Aspire E5-721-64T8 Touch Pad Replacement: Schritt 4, Bild 1 von 2 Acer Aspire E5-721-64T8 Touch Pad Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the battery from the motherboard.
    • Pull the battery up and out of the laptop.
  5. Acer Aspire E5-721-64T8 Touch Pad Replacement, Motherboard: Schritt 5, Bild 1 von 2 Acer Aspire E5-721-64T8 Touch Pad Replacement, Motherboard: Schritt 5, Bild 2 von 2
    • Remove the two 6mm Phillips #0 screws from the fan.
    • Disconnect the fan from the motherboard.
    • Remove the four 6mm Phillips #0 screws from the heat sink.
    • Lift and remove the heatsink assembly from laptop.
  6. Acer Aspire E5-721-64T8 Touch Pad Replacement: Schritt 6, Bild 1 von 1
    • Remove the Wi-Fi card by pulling it from the motherboard socket.
  7. Acer Aspire E5-721-64T8 Touch Pad Replacement: Schritt 7, Bild 1 von 1
    • Disconnect the display cable from the motherboard.
  8. Acer Aspire E5-721-64T8 Touch Pad Replacement: Schritt 8, Bild 1 von 1
    • Disconnect the speaker from the motherboard.
  9. Acer Aspire E5-721-64T8 Touch Pad Replacement: Schritt 9, Bild 1 von 2 Acer Aspire E5-721-64T8 Touch Pad Replacement: Schritt 9, Bild 2 von 2
    • Use a spudger to flip up the retaining flaps on the ribbon cable ZIF sockets.
  10. Acer Aspire E5-721-64T8 Touch Pad Replacement: Schritt 10, Bild 1 von 2 Acer Aspire E5-721-64T8 Touch Pad Replacement: Schritt 10, Bild 2 von 2
    • Use a spudger to flip up the retaining flap on the black ribbon cable ZIF socket.
  11. Acer Aspire E5-721-64T8 Touch Pad Replacement: Schritt 11, Bild 1 von 1
    • Lift the motherboard up from the narrow side and jiggle slightly so that way it doesn't get caught on the ports of the laptop case.
  12. Acer Aspire E5-721-64T8 Touch Pad Replacement, Touch Pad: Schritt 12, Bild 1 von 1
    • Peel the black adhesive film up.
  13. Acer Aspire E5-721-64T8 Touch Pad Replacement: Schritt 13, Bild 1 von 1
    • Remove the three 6mm Phillips #0 screws from touchpad.
  14. Acer Aspire E5-721-64T8 Touch Pad Replacement: Schritt 14, Bild 1 von 1
    • Use a spudger to flip up the retaining flap on the touchpad ribbon cable ZIF socket.
    • Remove the ribbon cable from the ZIF socket.
  15. Acer Aspire E5-721-64T8 Touch Pad Replacement: Schritt 15, Bild 1 von 2 Acer Aspire E5-721-64T8 Touch Pad Replacement: Schritt 15, Bild 2 von 2
    • Lift the touchpad up by the side closest to the middle of the laptop and pull up towards you to remove.
Abschluss
Ed Herrera
390 Reputation
3 Anleitungen geschrieben
USF Tampa, Team S7-G3, Passmore Spring 2018 Mitglied von USF Tampa, Team S7-G3, Passmore Spring 2018
USFT-PASSMORE-S18S7G3
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 281
