Einleitung
The hard drive is a relatively easy component to replace. That being said, you do have to be careful when removing it to not damage the connector.
Was du brauchst
Unscrew the 13 6.2mm screws located on the bottom of the laptop using the JIS #0 screwdriver.
Locate the hard drive and slide the hard drive to the left until it disconnects from the mother board.
3 weitere Personen haben diese Anleitung absolviert.
