Einleitung
This guide provides instructions on removing the hard drive from your Acer Aspire ES1-711-p1UV laptop. You may need to follow this guide if your laptop is having troubles loading multiple pages or tabs, or is low on memory. If these issues are occuring, you may need to replace your hard drive to install new memory.
Was du brauchst
Place the laptop face down on a flat, clean surface.
Remove all twenty-seven 7 mm screws on the back cover of the laptop with a Phillips #0 screwdriver. Screws are circled in red on the diagram.
Use the iFixit opening tool to pry open the four corners of the back cover of the laptop. You may need to use your hands to fully remove the cover.
Be sure to evenly apply pressure when removing the back cover.
Disconnect the colored bundled cable connectors from the motherboard. To do this, pull on the wires to disconnect the cable and remove the battery.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
