Zum Hauptinhalt wechseln
Acer Aspire ES1-711-P1UV Screen Replacement
Was du brauchst
  1. Acer Aspire ES1-711-P1UV Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place the laptop face down on a flat, clean surface.
    • Remove all twenty-seven 7 mm screws on the back cover of the laptop with a Phillips #0 screwdriver. Screws are circled in red on the diagram.
  2. Acer Aspire ES1-711-P1UV Screen Replacement: Schritt 2, Bild 1 von 1
    • Use the iFixit opening tool to pry open the four corners of the back cover of the laptop. You may need to use your hands to fully remove the cover.
    • Be sure to evenly apply pressure when removing the back cover.
  3. Acer Aspire ES1-711-P1UV Screen Replacement: Schritt 3, Bild 1 von 1
    • Remove the two 5 mm screws located on either side of the battery.
  4. Acer Aspire ES1-711-P1UV Screen Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the colored bundled cable connectors from the motherboard. To do this, pull on the wires to disconnect the cable and remove the battery.
  5. Acer Aspire ES1-711-P1UV Screen Replacement, Screen: Schritt 5, Bild 1 von 2 Acer Aspire ES1-711-P1UV Screen Replacement, Screen: Schritt 5, Bild 2 von 2
    • Place the laptop on a flat surface and open it to see the screen.
    • Using your fingers or a plastic opening tool, pry open the bezel that holds the screen in place.
  6. Acer Aspire ES1-711-P1UV Screen Replacement: Schritt 6, Bild 1 von 3 Acer Aspire ES1-711-P1UV Screen Replacement: Schritt 6, Bild 2 von 3 Acer Aspire ES1-711-P1UV Screen Replacement: Schritt 6, Bild 3 von 3
    • Use the Phillips #0 screwdriver to remove the fourteen 5mm screws around the screen.
    • Use the Phillips #0 screwdriver to remove the four 4mm screws holding in the screen.
    • Before unscrewing the screen, place a paper on the keyboard to protect the screen from scratches.
  7. Acer Aspire ES1-711-P1UV Screen Replacement: Schritt 7, Bild 1 von 2 Acer Aspire ES1-711-P1UV Screen Replacement: Schritt 7, Bild 2 von 2
    • With the screen on the paper, detach the Zero Insertion Force (ZIF) connector attaching the screen to the video cable inside of the front cover.
    • To remove the ZIF use your finger to flip up the top cover and gently pull the cable out.
    • Be sure to pry open the hinged flap not the connector socket
    • Gently remove the screen from laptop.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Sam Houston State, Team S17-G3, Blackburne Winter 2018 Mitglied von Sam Houston State, Team S17-G3, Blackburne Winter 2018
SHSU-BLACKBURNE-W18S17G3
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 814
