Zum Hauptinhalt wechseln
Acer Aspire M5-583P-6423 Battery Replacement
Was du brauchst
  1. Acer Aspire M5-583P-6423 Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Acer Aspire M5-583P-6423 Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Acer Aspire M5-583P-6423 Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Turn the computer off and close it. Disconnect the charging cable from the laptop and place the laptop upside down.
    • Remove seventeen M2.5x8mm screws on the back cover of the laptop with the Phillips #00 screwdriver.
  2. Acer Aspire M5-583P-6423 Battery Replacement: Schritt 2, Bild 1 von 2 Acer Aspire M5-583P-6423 Battery Replacement: Schritt 2, Bild 2 von 2
    • Push the back cover up from each side using the iFixit opening tool.
    • You’ll hear a popping sound as you lift the back cover.
    • Once the back cover is separated, you’ll see all the internal components of the laptop.
  3. Acer Aspire M5-583P-6423 Battery Replacement: Schritt 3, Bild 1 von 2 Acer Aspire M5-583P-6423 Battery Replacement: Schritt 3, Bild 2 von 2
    • Pull the rainbow cord out by using the iFixit opening tool on each side of its connecting slot.
    • This step can be done by using your fingers, but its highly recommended to use the iFixit removal tool instead.
  4. Acer Aspire M5-583P-6423 Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove the M2.5 x 3mm screw that holds down the battery using the Phillips #00 screwdriver.
  5. Acer Aspire M5-583P-6423 Battery Replacement: Schritt 5, Bild 1 von 1
    • Lift the battery up from its edges and pull back slightly towards the hinges to remove the battery.
    • The battery is now detached from the laptop and can be set aside.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 20
Insgesamt: 751
