Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
The first step will be to remove all the screws from the back cover of the device. Then we will remove the back cover. Next, we will remove the screw holding the battery in place. Once that is complete the battery will be unplugged and removed. These steps will be repeated in reverse to put everything back together.
  1. Remove all 18 marked screws (2.12 mm) using a Phillips #1 Screwdriver.
    • Remove all 18 marked screws (2.12 mm) using a Phillips #1 Screwdriver.
  2. Use the spudger to slowly work your way around the perimeter starting at the marked location to pop the bottom cover off. Use the spudger to slowly work your way around the perimeter starting at the marked location to pop the bottom cover off.
    • Use the spudger to slowly work your way around the perimeter starting at the marked location to pop the bottom cover off.
  3. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  4. Remove the 1 marked screw (3.3 mm) holding the battery in place using a Phillips #1 Screwdriver. Remove the 1 marked screw (3.3 mm) holding the battery in place using a Phillips #1 Screwdriver.
    • Remove the 1 marked screw (3.3 mm) holding the battery in place using a Phillips #1 Screwdriver.
  5. Unplug the marked plug from the motherboard and this will complete the removal of the battery. Unplug the marked plug from the motherboard and this will complete the removal of the battery.
    • Unplug the marked plug from the motherboard and this will complete the removal of the battery.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Daniel Bates
154 Reputation
1 Anleitung geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 11
Letzten 30 Tage: 51
Insgesamt: 1,285
