Einleitung
This guide will show how to remove and replace the hard drive of an Acer 583P-9688.
Was du brauchst
Remove the 18 marked screws (2.12 mm) using a Phillips #1 head screwdriver.
Use the spudger to slowly work your way around the perimeter starting at the marked location to pop the bottom cover off.
To remove the hard drive, carefully take it out of the brackets holding it in place. Once you have it out of the brackets, remove the connector from the hard drive.
3 weitere Personen haben diese Anleitung absolviert.
