Einleitung
In this guide you will learn how to replace the RAM in an Acer Aspire M5-583P-9688 laptop.
Ersatzteile
  1. Remove all 18 marked screws (2.12 mm) using a Phillips #1 screwdriver.
    • Remove all 18 marked screws (2.12 mm) using a Phillips #1 screwdriver.
  2. Use the spudger to slowly work your way around the perimeter starting at the marked location to pop the bottom cover off.
    • Use the spudger to slowly work your way around the perimeter starting at the marked location to pop the bottom cover off.
    • Pull back the brackets holding the RAM in place and remove the RAM.
    • Be careful when pulling the brackets away from the RAM. Don't pull on them too much so they don't break.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Collin Steel
Mitglied seit 29.01.2018
325 Reputation
2 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 80
