Zum Hauptinhalt wechseln
Acer Aspire One 532h-2527 Hard Disk Drive Replacement
Was du brauchst
  1. Acer Aspire One 532h-2527 Hard Disk Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Press the power button to turn off the netbook.
  2. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: Schritt 2, Bild 1 von 1
    • Place the netbook bottom-side-up on a flat surface.
    • Locate the unlock latch on the top right corner of the back.
  3. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: Schritt 3, Bild 1 von 1
    • To unlock the battery, slide the lock latch in the direction indicated by the unlocking icon. You should see the orange indicator which means that the latch is unlocked.
  4. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: Schritt 4, Bild 1 von 3 Acer Aspire One 532h-2527 Hard Disk Drive Replacement: Schritt 4, Bild 2 von 3 Acer Aspire One 532h-2527 Hard Disk Drive Replacement: Schritt 4, Bild 3 von 3
    • On the opposite side, slide and hold the release latch.
    • Gently slide the battery out.
  5. Acer Aspire One 532h-2527 Hard Disk Drive Replacement, Back Plate: Schritt 5, Bild 1 von 1
    • Use a #0 Phillips screwdriver to remove the three 6mm screws from the larger back plate.
  6. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: Schritt 6, Bild 1 von 1
    • Use the plastic opening tool on the recessed notch at the bottom of the larger plate to gently lift the plate.
  7. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: Schritt 7, Bild 1 von 1
    • Once the plate becomes unhinged, gently rotate the plate to take it off of the device.
  8. Acer Aspire One 532h-2527 Hard Disk Drive Replacement, Hard Disk Drive: Schritt 8, Bild 1 von 1
    • Locate the HDD after the back plate is removed. It will be the large rectangle that takes up most of the space.
  9. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: Schritt 9, Bild 1 von 2 Acer Aspire One 532h-2527 Hard Disk Drive Replacement: Schritt 9, Bild 2 von 2
    • Gently press down on the HDD and slide it to the left as far as it will go.
  10. Acer Aspire One 532h-2527 Hard Disk Drive Replacement: Schritt 10, Bild 1 von 2 Acer Aspire One 532h-2527 Hard Disk Drive Replacement: Schritt 10, Bild 2 von 2
    • Grab the edges of the HDD, slightly rotate it, and gently pull it out.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Erica Romero
481 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 11-6, Blackwell Fall 2016 Mitglied von USF Tampa, Team 11-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G6
3 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 1,789
