Zum Hauptinhalt wechseln
Acer Aspire One 532h-2527 Keyboard Replacement
Was du brauchst
  1. Acer Aspire One 532h-2527 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Press the power button to turn off the netbook.
  2. Acer Aspire One 532h-2527 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Place the netbook bottom-side-up on a flat surface.
    • Locate the unlock latch on the top right corner of the back.
  3. Acer Aspire One 532h-2527 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • To unlock the battery, slide the lock latch in the direction indicated by the unlocking icon. You should see the orange indicator which means that the latch is unlocked.
  4. Acer Aspire One 532h-2527 Keyboard Replacement: Schritt 4, Bild 1 von 3 Acer Aspire One 532h-2527 Keyboard Replacement: Schritt 4, Bild 2 von 3 Acer Aspire One 532h-2527 Keyboard Replacement: Schritt 4, Bild 3 von 3
    • On the opposite side, slide and hold the release latch.
    • Gently slide the battery out.
  5. Acer Aspire One 532h-2527 Keyboard Replacement, Keyboard: Schritt 5, Bild 1 von 1
    • Locate the three latches along the top crevice along the top rows of keys and the plastic boarder.
  6. Acer Aspire One 532h-2527 Keyboard Replacement: Schritt 6, Bild 1 von 3 Acer Aspire One 532h-2527 Keyboard Replacement: Schritt 6, Bild 2 von 3 Acer Aspire One 532h-2527 Keyboard Replacement: Schritt 6, Bild 3 von 3
    • Using the metal spudger, gently pry each tab releasing the keyboard. Make sure as you move to each new one that the previous one does not reset itself.
  7. Acer Aspire One 532h-2527 Keyboard Replacement: Schritt 7, Bild 1 von 1
    • Check for tabs on the side of the keyboard.
    • If there are no tabs lift the top of the keyboard.
  8. Acer Aspire One 532h-2527 Keyboard Replacement: Schritt 8, Bild 1 von 3 Acer Aspire One 532h-2527 Keyboard Replacement: Schritt 8, Bild 2 von 3 Acer Aspire One 532h-2527 Keyboard Replacement: Schritt 8, Bild 3 von 3
    • Locate the sticker-like connecter on the back of the keyboard. Carefully unplug it.
  9. Acer Aspire One 532h-2527 Keyboard Replacement: Schritt 9, Bild 1 von 2 Acer Aspire One 532h-2527 Keyboard Replacement: Schritt 9, Bild 2 von 2
    • Remove keyboard.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Jair Burgos
425 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 11-6, Blackwell Fall 2016 Mitglied von USF Tampa, Team 11-6, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G6
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 723
