Einleitung
This guide will show how to remove the small back plate on your netbook. The removal of the plate is necessary to access your netbook’s RAM.
Was du brauchst
Place the netbook bottom-side-up on a flat surface.
Locate the unlock latch on the top right corner of the back.
To unlock the battery, slide the lock latch in the direction indicated by the unlocking icon. You should see the orange indicator which means that the latch is unlocked.
On the opposite side, slide and hold the release latch.
Gently slide the battery out.
Use the #0 Phillips Screw bit with the Screwdriver to remove the single 6mm Phillips screw from the small back plate.
Use the plastic opening tool on the recessed notch at the bottom of the small plate to gently lift the plate up
Once the plate becomes unhinged, gently rotate the plate to take it of of the device.
Using two fingers, gently spread the latches on the sides of the RAM card until the RAM card props up.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
