Zum Hauptinhalt wechseln
Acer Aspire One 532h-2806 Keyboard Replacement
Was du brauchst
  1. Acer Aspire One 532h-2806 Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Make sure the laptop is turned off and the battery is removed.
    • Above the top row of the keys, locate three plastic latches.
  2. Acer Aspire One 532h-2806 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Use the medal spudger to press each tab. The keyboard should release.
    • Slide the spudger, so that the tabs do not reset after pressing each one.
  3. Acer Aspire One 532h-2806 Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Gently lift the keyboard up.
    • The keyboard ribbon cable is still attached to the motherboard.
  4. Acer Aspire One 532h-2806 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Carefully unplug the connector sticker on the back of the keyboard.
    • Be gentle, do not force it out.
  5. Acer Aspire One 532h-2806 Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Remove the keyboard.
Abschluss
Julie Paula
527 Reputation
4 Anleitungen geschrieben
Oakland University, Team 2-4, Ruskiewicz Winter 2017 Mitglied von Oakland University, Team 2-4, Ruskiewicz Winter 2017
OAK-RUSKIEWICZ-W17S2G4
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 363
