Einleitung
This guide illustrates how to remove the RAM card from the Acer Aspire One 532h-2806, which is located on the bottom side of the netbook. This guide may be needed if your laptop is having internal hard drive issues.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Use a Phillips #0 screwdriver to remove the 6mm screw from the back of the computer.
Use an opening tool to remove the plastic plate covering the RAM, using the notch on the bottom right side.
Remove the plate.
At the same time, press the latches on the sides of the RAM card to remove it.
The RAM should pop up.
2 weitere Nutzer haben diese Anleitung absolviert.
