Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide illustrates how to remove the RAM card from the Acer Aspire One 532h-2806, which is located on the bottom side of the netbook. This guide may be needed if your laptop is having internal hard drive issues.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Turn off the computer and remove the battery before removing parts.
    • Turn off the computer and remove the battery before removing parts.
    • Use a Phillips #0 screwdriver to remove the 6mm screw from the back of the computer.
  2. Use an opening tool to remove the plastic plate covering the RAM, using the notch on the bottom right side. Remove the plate.
    • Use an opening tool to remove the plastic plate covering the RAM, using the notch on the bottom right side.
    • Remove the plate.
  3. At the same time, press the latches on the sides of the RAM card to remove it. The RAM should pop up.
    • At the same time, press the latches on the sides of the RAM card to remove it.
    • The RAM should pop up.
  4. Remove the RAM card.
    • Remove the RAM card.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Julie Paula
503 Reputation
4 Anleitungen geschrieben
Oakland University, Team 2-4, Ruskiewicz Winter 2017 Mitglied von Oakland University, Team 2-4, Ruskiewicz Winter 2017
OAK-RUSKIEWICZ-W17S2G4
3 Mitglieder
8 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 13
Insgesamt: 314
