Einleitung
This guide will teach one how to fully remove the screen from the Acer Aspire One 532h-2806. A Phillips #0 Screwdriver and an opener tool is required to complete this guide. This guide may be needed if the screen is cracked and needs to be replaced.
Was du brauchst
Locate the two circular black stickers at the bottom corners of the laptop screen.
Remove the stickers.
Remove the two 6mm screws on each side of the screen with a Phillips #0 screwdriver.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
