Zum Hauptinhalt wechseln
Acer Aspire One 532h-2806 Screen Replacement
Was du brauchst
  1. Acer Aspire One 532h-2806 Screen Replacement, Screen: Schritt 1, Bild 1 von 2 Acer Aspire One 532h-2806 Screen Replacement, Screen: Schritt 1, Bild 2 von 2
    • Turn the device off before beginning any replacements.
    • Locate the two circular black stickers at the bottom corners of the laptop screen.
    • Remove the stickers.
    • Two 6mm Phillips Screws should now be visible.
  2. Acer Aspire One 532h-2806 Screen Replacement: Schritt 2, Bild 1 von 2 Acer Aspire One 532h-2806 Screen Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #0 Screwdriver to remove the two 6mm screws from the screen.
  3. Acer Aspire One 532h-2806 Screen Replacement: Schritt 3, Bild 1 von 2 Acer Aspire One 532h-2806 Screen Replacement: Schritt 3, Bild 2 von 2
    • Using the opener tool, remove the plastic cover, surrounding the screen.
    • It is normal to hear clicking sounds as the plastic cover is removed.
  4. Acer Aspire One 532h-2806 Screen Replacement: Schritt 4, Bild 1 von 3 Acer Aspire One 532h-2806 Screen Replacement: Schritt 4, Bild 2 von 3 Acer Aspire One 532h-2806 Screen Replacement: Schritt 4, Bild 3 von 3
    • Remove the four 6mm Phillips screws surrounding the screen.
    • These are holding the screen in place. After the screws are removed, the screen should remove itself from the plastic outer cover.
  5. Acer Aspire One 532h-2806 Screen Replacement: Schritt 5, Bild 1 von 1
    • Peel back the fuss cable from the outer laptop plastic cover.
    • Be careful, not to yank or rip the cable, it should gently peel back.
  6. Acer Aspire One 532h-2806 Screen Replacement: Schritt 6, Bild 1 von 1
    • Locate the ZIF (zero insertion force) Cable.
    • Peel back any tape if necessary
    • Carefully unplug it.
    • Do not pull hard, it should remove itself easily.
  7. Acer Aspire One 532h-2806 Screen Replacement: Schritt 7, Bild 1 von 2 Acer Aspire One 532h-2806 Screen Replacement: Schritt 7, Bild 2 von 2
    • Remove the two 6mm screws on each side of the screen with a Phillips #0 screwdriver.
  8. Acer Aspire One 532h-2806 Screen Replacement: Schritt 8, Bild 1 von 3 Acer Aspire One 532h-2806 Screen Replacement: Schritt 8, Bild 2 von 3 Acer Aspire One 532h-2806 Screen Replacement: Schritt 8, Bild 3 von 3
    • Remove the screen.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Julie Paula
527 Reputation
4 Anleitungen geschrieben
Oakland University, Team 2-4, Ruskiewicz Winter 2017 Mitglied von Oakland University, Team 2-4, Ruskiewicz Winter 2017
OAK-RUSKIEWICZ-W17S2G4
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 331
