Zum Hauptinhalt wechseln
Acer Aspire One 722 Hard Drive Replacement
Was du brauchst
    1. Acer Aspire One 722 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
      • Power down the netbook by pressing the power button on the top left corner.
      Frag FixBot
      Kommentar hinzufügen
    2. Acer Aspire One 722 Hard Drive Replacement: Schritt 2, Bild 1 von 1
      • Close the netbook and flip it over so that the back is facing up.
      Frag FixBot
    3. Acer Aspire One 722 Hard Drive Replacement: Schritt 3, Bild 1 von 1
      • Slide the button below the battery to the right while simultaneously pulling the battery out.
      Frag FixBot
    4. Acer Aspire One 722 Hard Drive Replacement: Schritt 4, Bild 1 von 2 Acer Aspire One 722 Hard Drive Replacement: Schritt 4, Bild 2 von 2
      • If necessary, remove the old battery and replace it with a new one.
      Frag FixBot
    5. Acer Aspire One 722 Hard Drive Replacement: Schritt 5, Bild 1 von 1
      • Check the thin grooves on the side of the battery entry and line the replacement battery up to the grooves.
      Frag FixBot
    1. Acer Aspire One 722 Hard Drive Replacement, Hard Drive: Schritt 6, Bild 1 von 1
      • Ensure the Laptop is powered down with the battery removed prior to beginning.
      • With the battery cavity facing away from you, use the Phillips #0 to remove the center screw which secures the backplate.
      • Make sure to keep track of these screws for reassembly.
      Frag FixBot
    2. Acer Aspire One 722 Hard Drive Replacement: Schritt 7, Bild 1 von 1
      • Gently lift up and pull away the backplate from the chassis to remove.
      Frag FixBot
    3. Acer Aspire One 722 Hard Drive Replacement: Schritt 8, Bild 1 von 1
      • With the backplate removed, locate the HDD in the upper left corner of the device.
      • Use the Phillips #0 screwdriver to remove the four corner screws securing the HDD to the chassis.
      Frag FixBot
    4. Acer Aspire One 722 Hard Drive Replacement: Schritt 9, Bild 1 von 2 Acer Aspire One 722 Hard Drive Replacement: Schritt 9, Bild 2 von 2
      • Gently lift and secure the HDD with one hand and carefully remove the SATA and power connections with your other hand.
      • Once removed, store the replaced drive in an anti-static environment to ensure its integrity.
      Frag FixBot
    5. Acer Aspire One 722 Hard Drive Replacement: Schritt 10, Bild 1 von 3 Acer Aspire One 722 Hard Drive Replacement: Schritt 10, Bild 2 von 3 Acer Aspire One 722 Hard Drive Replacement: Schritt 10, Bild 3 von 3
      • With your replacement HDD in hand, reseat the power and SATA cables removed from the previous drive.
      • The plugs are diffrent sizes so there is no fear of mixing them up
      • With the cables attached, align the four mounting points in the corner of the drive with the chassis and reseat the four Phillips #0 screws that were removed earlier.
      Frag FixBot
Abschluss
To reassemble your device, follow these instructions in reverse order., taking special care in replacing the back cover. and battery.
4 weitere Personen haben diese Anleitung absolviert.
UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015 Mitglied von UMass Dartmouth, Team 5-6, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G6
3 Mitglieder
60 Anleitungen geschrieben
1 Kommentar zur Anleitung
لا يعمل بعد انسطاب عليه ماء ما الحل
Belql Sayes - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 52
Insgesamt: 6,424
