Einleitung
In order to access the primary components of the Acer Aspire One 725-0845, you will need to remove the back-plate, detailed here.
Was du brauchst
Using the JIS J1 Screwdriver Bit and Driver, remove the center screw (7.0 mm) from the back-plate.
Using your hands, slide the back-plate away from the center of the device and remove.
Eine weitere Person hat diese Anleitung absolviert.
