Einleitung
This guide will help you replace the display of your Acer Aspire One 751h-1948.
Was du brauchst
Unlock the right side of the battery by sliding the battery lock to the right. Then slide the left lock to the left and remove the battery.
Unscrew the two Phillips #0 (M2-L2.5 mm) holding down the network card panel.
Unplug the two connecting cables by lifting them up. They should unclip easily.
Remove the screw Phillips #0 (M2-L3 mm) holding down the network card. Pull out the card.
Unscrew the Phillips 0# (M2 L2.5 mm) screw and remove the cover panel.
Use the plastic opening tool to push in each of the four clips and carefully lift the keyboard.
When you remove the keyboard, be careful not to damage the ribbon cable that attaches it to the motherboard.
Unplug the ribbon cable by gently lifting the black tab up. Then remove the cable.
Use the spudger to remove all rubber pads covering the screws for the upper casing.
Then unscrew all the Phillips #0 (M2-L5 mm) screws under rubber pads.
Separate the screen from the metal frame that secures it to the upper casing and remove the screen.
