Einleitung
This guide will show you how to replace the Aspire One 751h-1948 keyboard.
Was du brauchst
Unlock the right side of the battery by sliding the battery lock to the right. Then slide the left lock to the left and remove the battery.
Use the plastic opening tool to push in each of the four clips and carefully lift the keyboard.
When you remove the keyboard, be careful not to damage the ribbon cable that attaches it to the motherboard.
Unplug the ribbon cable by gently lifting the black tab up. Then remove the cable.
Eine weitere Person hat diese Anleitung absolviert.
