Einleitung
Use this guide to replace the RAM in the Acer Aspire One 751h-1948
Was du brauchst
Below the battery to the right corner of the laptop the RAM card will be located there.
There are two Phillips #0 (M2-L2.5 mm) screws that is securing the cover. Remove these screws and lift up the cover panel.
Use your thumbs to push the RAM clips out. The card should lift up when its released. It can then be removed.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
