Zum Hauptinhalt wechseln
Acer Aspire One A150-1570 Motherboard Replacement
Was du brauchst
  1. Acer Aspire One A150-1570 Motherboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Flip device over so that the battery is farthest from you.
    • Identify the switch on the upper left corner and push it left to be in "unlocked" position.
  2. Acer Aspire One A150-1570 Motherboard Replacement: Schritt 2, Bild 1 von 2 Acer Aspire One A150-1570 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Identify the latch on the upper right hand corner. Drag and hold the latch to the right.
    • Pull the battery out.
  3. Acer Aspire One A150-1570 Motherboard Replacement: Schritt 3, Bild 1 von 2 Acer Aspire One A150-1570 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Now flip device back over to show the keyboard.
    • Locate the three tabs at the top of the keyboard.
  4. Acer Aspire One A150-1570 Motherboard Replacement: Schritt 4, Bild 1 von 3 Acer Aspire One A150-1570 Motherboard Replacement: Schritt 4, Bild 2 von 3 Acer Aspire One A150-1570 Motherboard Replacement: Schritt 4, Bild 3 von 3
    • Start on the top-right and use the spudger to push off the tab from the keyboard.
    • Move to the middle tab while still holding the right side up so the tab doesn't fall back into place.
    • Continue to hold up keyboard while disconnecting the last tab.
    • DO NOT lift keyboard yet. This will be addressed in the next step.
  5. Acer Aspire One A150-1570 Motherboard Replacement: Schritt 5, Bild 1 von 3 Acer Aspire One A150-1570 Motherboard Replacement: Schritt 5, Bild 2 von 3 Acer Aspire One A150-1570 Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Here you can see that the keyboard is still attached to the device.
    • Use the Spudger to lift the ZIF (Zero Insertion Force) to release the keyboard ribbon.
    • Once tab is lifted, the keyboard ribbon should come right out.
  6. Acer Aspire One A150-1570 Motherboard Replacement, Internal Wireless Card: Schritt 6, Bild 1 von 1
    • Close and flip the device over so you can have a good view of all the screws.
    • Locate and remove the three 3.9mm screws where the battery was removed from.
    • Locate and and remove the two 5.8mm screws located underneath the bumpers.
    • Locate and remove the three 5.8mm remaining screws at the top of the device.
  7. Acer Aspire One A150-1570 Motherboard Replacement: Schritt 7, Bild 1 von 3 Acer Aspire One A150-1570 Motherboard Replacement: Schritt 7, Bild 2 von 3 Acer Aspire One A150-1570 Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Flip and reopen device to where you can view the internal panel.
    • Locate the ZIF connecting the mouse panel to the motherboard.
    • Flip up the black plastic hinge and carefully pull out the ZIF connector.
  8. Acer Aspire One A150-1570 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Locate and remove all five 4.7mm black screws.
    • Locate and remove the one 4.3mm silver screw.
  9. Acer Aspire One A150-1570 Motherboard Replacement: Schritt 9, Bild 1 von 2 Acer Aspire One A150-1570 Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Pick a corner and slowly lift up the panel while running your finger underneath to pop off the seals.
    • Make sure to move slowly. You do not want to crack the plastic from being to rough or moving to fast.
  10. Acer Aspire One A150-1570 Motherboard Replacement: Schritt 10, Bild 1 von 2 Acer Aspire One A150-1570 Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Locate the internal wireless card.
    • Remove the one 3.9mm screw holding it down.
  11. Acer Aspire One A150-1570 Motherboard Replacement: Schritt 11, Bild 1 von 3 Acer Aspire One A150-1570 Motherboard Replacement: Schritt 11, Bild 2 von 3 Acer Aspire One A150-1570 Motherboard Replacement: Schritt 11, Bild 3 von 3
    • Carefully disconnect the black and white cable from the internal wireless card.
    • Pull the internal wireless card straight out.
  12. Acer Aspire One A150-1570 Motherboard Replacement, Motherboard: Schritt 12, Bild 1 von 1
    • Locate and remove the four 3.9mm screws on the right side of your device.
  13. Acer Aspire One A150-1570 Motherboard Replacement: Schritt 13, Bild 1 von 2 Acer Aspire One A150-1570 Motherboard Replacement: Schritt 13, Bild 2 von 2
    • Locate the display cable in the upper left corner of your device.
    • Carefully disconnect the display cable.
  14. Acer Aspire One A150-1570 Motherboard Replacement: Schritt 14, Bild 1 von 2 Acer Aspire One A150-1570 Motherboard Replacement: Schritt 14, Bild 2 von 2
    • Locate the speaker cable at the bottom of the mother board.
    • Carefully pull the cable to disconnect the speaker from the mother board.
  15. Acer Aspire One A150-1570 Motherboard Replacement: Schritt 15, Bild 1 von 2 Acer Aspire One A150-1570 Motherboard Replacement: Schritt 15, Bild 2 von 2
    • Locate and remove the last two remaining 4.7mm screws in the upper left corner of the motherboard.
    • Gently lift the motherboard off the device frame.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Sam Houston State, Team 12-5, Blackburne Fall 2016 Mitglied von Sam Houston State, Team 12-5, Blackburne Fall 2016
SHSU-BLACKBURNE-F16S12G5
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 16
Insgesamt: 1,269
