Zum Hauptinhalt wechseln
Acer Aspire One AO756-2623 Back Cover Replacement
Was du brauchst
  1. Acer Aspire One AO756-2623 Back Cover Replacement, Battery: Schritt 1, Bild 1 von 1
    • Orient the ACER Aspire One to where the bottom of the laptop is facing upward as shown in the picture.
  2. Acer Aspire One AO756-2623 Back Cover Replacement: Schritt 2, Bild 1 von 1
    • Locate the circular slot positioned at the bottom right of the battery.
  3. Acer Aspire One AO756-2623 Back Cover Replacement: Schritt 3, Bild 1 von 3 Acer Aspire One AO756-2623 Back Cover Replacement: Schritt 3, Bild 2 von 3 Acer Aspire One AO756-2623 Back Cover Replacement: Schritt 3, Bild 3 von 3
    • Insert a spudger and slide the tab to the right.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Hold the tab in the right-hand position and firmly push or pull the battery upward to remove it from the laptop.
  4. Acer Aspire One AO756-2623 Back Cover Replacement, Back Cover: Schritt 4, Bild 1 von 1
    • Locate the single 6 mm Phillips screw in the lower middle of the back plate.
    • Remove the screw using a Phillips #0 Screwdriver.
  5. Acer Aspire One AO756-2623 Back Cover Replacement: Schritt 5, Bild 1 von 2 Acer Aspire One AO756-2623 Back Cover Replacement: Schritt 5, Bild 2 von 2
    • Slide the back plate downward to remove it from the laptop.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Colin Rodwell
382 Reputation
3 Anleitungen geschrieben
Clemson, Team 7-1, Benson Spring 2016 Mitglied von Clemson, Team 7-1, Benson Spring 2016
CLEM-BENSON-S16S7G1
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 18
Insgesamt: 1,853
