Einleitung
A dysfunctional battery can be the root of multiple problems within the laptop. Replacing the battery requires one step and is also necessary if any of the other parts inside of the laptop need to be replaced for safety measures.
Was du brauchst
Orient the ACER Aspire One to where the bottom of the laptop is facing upward as shown in the picture.
Insert a spudger and slide the tab to the right.
Hold the tab in the right-hand position and firmly push or pull the battery upward to remove it from the laptop.
2 weitere Personen haben diese Anleitung absolviert.
