Einleitung
A dysfunctional hard drive can completely ruin the life of an otherwise functional computer; therefore, if any problems arise regarding the hard drive, it should be fixed or replaced. Removing the hard drive requires the battery and back cover to be removed and then only a few screws need to be removed to completely take out the hard drive.
Was du brauchst
Orient the ACER Aspire One to where the bottom of the laptop is facing upward as shown in the picture.
Insert a spudger and slide the tab to the right.
Hold the tab in the right-hand position and firmly push or pull the battery upward to remove it from the laptop.
Locate the single 6 mm Phillips screw in the lower middle of the back plate.
Remove the screw using a Phillips #0 Screwdriver.
Locate the four 6 mm Phillips screws pictured necessary to remove the hard drive.
Remove all four of the screws using a Phillips #0 Screwdriver.
Locate the two tabs that keep the hard drive ribbon cable connected to the laptop.
Using a spudger, gently push in the indicated tabs.
While holding down the tabs, slide the ribbon cable to the left to remove it from the laptop.
3 weitere Personen haben diese Anleitung absolviert.
