Zum Hauptinhalt wechseln
Acer Aspire One AO756-2623 Touchpad Replacement
Was du brauchst
  1. Acer Aspire One AO756-2623 Touchpad Replacement, Battery: Schritt 1, Bild 1 von 1
    • Orient the ACER Aspire One to where the bottom of the laptop is facing upward as shown in the picture.
  2. Acer Aspire One AO756-2623 Touchpad Replacement: Schritt 2, Bild 1 von 1
    • Locate the circular slot positioned at the bottom right of the battery.
  3. Acer Aspire One AO756-2623 Touchpad Replacement: Schritt 3, Bild 1 von 3 Acer Aspire One AO756-2623 Touchpad Replacement: Schritt 3, Bild 2 von 3 Acer Aspire One AO756-2623 Touchpad Replacement: Schritt 3, Bild 3 von 3
    • Insert a spudger and slide the tab to the right.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Hold the tab in the right-hand position and firmly push or pull the battery upward to remove it from the laptop.
  4. Acer Aspire One AO756-2623 Touchpad Replacement, Back Cover: Schritt 4, Bild 1 von 1
    • Locate the single 6 mm Phillips screw in the lower middle of the back plate.
    • Remove the screw using a Phillips #0 Screwdriver.
  5. Acer Aspire One AO756-2623 Touchpad Replacement: Schritt 5, Bild 1 von 2 Acer Aspire One AO756-2623 Touchpad Replacement: Schritt 5, Bild 2 von 2
    • Slide the back plate downward to remove it from the laptop.
  6. Acer Aspire One AO756-2623 Touchpad Replacement, Keyboard: Schritt 6, Bild 1 von 1
    • Locate the eighteen 6 mm Phillips screws that are required to remove the keyboard.
    • Remove all screws using a Phillips #0 screwdriver.
  7. Acer Aspire One AO756-2623 Touchpad Replacement: Schritt 7, Bild 1 von 1
    • Orient the laptop to where the open screen is facing towards you.
    • Slide the spuldger into the indicated crease.
    • Firmly slide spudger all the way around the laptop to pry the keyboard away from the bottom of the laptop.
    • Loud cracking noises will be heard during this step.
  8. Acer Aspire One AO756-2623 Touchpad Replacement: Schritt 8, Bild 1 von 3 Acer Aspire One AO756-2623 Touchpad Replacement: Schritt 8, Bild 2 von 3 Acer Aspire One AO756-2623 Touchpad Replacement: Schritt 8, Bild 3 von 3
    • Remove the green dotted ribbon cable by sliding it straight out of the clamp holding it in using a plastic spudger.
    • Locate the two tabs that are holding the larger black ribbon cable in place.
    • Remove the larger black ribbon cable by pressing in the tabs and sliding it straight out of the clamp holding it in using a plastic spudger.
    • To remove the keyboard, lift the keyboard straight away from the rest of the laptop.
  9. Acer Aspire One AO756-2623 Touchpad Replacement: Schritt 9, Bild 1 von 3 Acer Aspire One AO756-2623 Touchpad Replacement: Schritt 9, Bild 2 von 3 Acer Aspire One AO756-2623 Touchpad Replacement: Schritt 9, Bild 3 von 3
    • Locate the ten 6 mm Phillips screws that connect the keyboard to the rest of the laptop and remove them with a Phillips #0 Screwdriver.
    • Locate the four 6 mm Phillips screws hidden beneath black tape by lifting up the black tape and remove them with a Phillips #0 Screwdriver.
    • To remove keyboard from the rest of the laptop, pull keyboard straight up.
  10. Acer Aspire One AO756-2623 Touchpad Replacement, Touchpad: Schritt 10, Bild 1 von 3 Acer Aspire One AO756-2623 Touchpad Replacement, Touchpad: Schritt 10, Bild 2 von 3 Acer Aspire One AO756-2623 Touchpad Replacement, Touchpad: Schritt 10, Bild 3 von 3
    • Take the keyboard frame and place it face down as shown.
    • To remove the touchpad from the rest of the laptop, pull it straight out.
Abschluss
To put the laptop together, follow these instructions in the reverse order.
Clemson, Team 7-1, Benson Spring 2016 Mitglied von Clemson, Team 7-1, Benson Spring 2016
CLEM-BENSON-S16S7G1
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 15
Insgesamt: 2,179
