Einleitung
The motherboard is a key component for any laptop and a damaged motherboard means that the laptop will not work as intended. This guide shows you how to replace the motherboard for this laptop.
Was du brauchst
Power the laptop off.
Flip the laptop over and position it so the opening faces you.
Remove the rubber foot located near the opening side of the device using tweezers.
Identify the HDMI port located in the side of the laptop opposite to the power button.
Insert the plastic opening tool into the divet of the back panel located above the HDMI port.
Pry along the laptop frame until the back panel comes loose.
Rotate the device so the opening faces you again.
Hold the back panel away from the laptop and remove the 4-mm screw using the PH0 screwdriver.
Lift the back panel gently.
Unplug the cable that connects the battery to the motherboard.
Detach the back panel, which still includes the battery.
Position the computer so the opening side faces you.
Remove the tape holding the WiFi module using tweezers.
Remove the 3-mm screw that holds the WiFi module to the motherboard using the PH0 screwdriver.
Lift the white hinge that holds the cable with a blue plastic strip.
Pull the blue strip away from the motherboard.
Lift the wider hinge located at the top of the motherboard holding another grey strip cable.
Pull the strip cable away from the motherboard.
Remove the four 4-mm screws holding the metallic plate using a PH0 screwdriver.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
