Einleitung
Does the sound out of your speakers sound distorted or poor? Follow this guide to replace your speakers.
Was du brauchst
Identify the HDMI port located in the side of the laptop opposite to the power button.
Insert the plastic opening tool into the divet of the back panel located above the HDMI port.
Pry along the laptop frame until the back panel comes loose.
Rotate the device so the opening faces you again.
Hold the back panel away from the laptop and remove the 4-mm screw using the PH0 screwdriver.
Lift the back panel gently.
Unplug the cable that connects the battery to the motherboard.
Detach the back panel, which still includes the battery.
Unhook the speaker by sliding it to one side first and then by lifting it up.
Repeat this step for the other speaker.
