Einleitung
The battery is a key component to giving the laptop power. Without the battery there will be no power for the laptop to function properly. This guide will show you how to remove and replace the battery.
Was du brauchst
Insert a plastic opening tool under the bottom cover and slid it around the perimeter until all of the clips release.
Use a spudger to flip up the retaining flaps on the ribbon cable ZIF sockets.
Remove the ribbon cables from the sockets.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
