Einleitung
The display is the main interaction with the user providing image. This outline will show you how to remove and replace the display from the device.
  1. Remove the ten 7mm Phillips #0 screws from the bottom. Remove the ten 7mm Phillips #0 screws from the bottom.
    • Remove the ten 7mm Phillips #0 screws from the bottom.
  2. Insert a plastic opening tool under the bottom cover and slid it around the perimeter until all of the clips release. Insert a plastic opening tool under the bottom cover and slid it around the perimeter until all of the clips release.
    • Insert a plastic opening tool under the bottom cover and slid it around the perimeter until all of the clips release.
  3. Remove the two 5mm Phillips #0 screws from the battery. Remove the two 5mm Phillips #0 screws from the battery.
    • Remove the two 5mm Phillips #0 screws from the battery.
  4. Use a spudger to flip up the retaining flaps on the  ribbon cable ZIF sockets. Remove the ribbon cables from the sockets. Remove the ribbon cables from the sockets.
    • Use a spudger to flip up the retaining flaps on the ribbon cable ZIF sockets.
    • Remove the ribbon cables from the sockets.
  5. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  6. Disconnect the battery from the motherboard. Remove the battery. Remove the battery.
    • Disconnect the battery from the motherboard.
    • Remove the battery.
  7. The battery is installed in these pictures but should always be removed before any part replacement. Remove the four 5mm Phillips #0 screws from the display hinge.
    • The battery is installed in these pictures but should always be removed before any part replacement.
    • Remove the four 5mm Phillips #0 screws from the display hinge.
  8. Disconnect the two antenna cables from the Wi-fi card. Disconnect the two antenna cables from the Wi-fi card.
    • Disconnect the two antenna cables from the Wi-fi card.
  9. Disconnect the display cable by pulling it down and towards you. Disconnect the display cable by pulling it down and towards you.
    • Disconnect the display cable by pulling it down and towards you.
  10. Lift the bottom half of the computer away from the screen while keeping the screen flat on the table surface. This will allow the hinges holding the screen in place to lift up.
    • Lift the bottom half of the computer away from the screen while keeping the screen flat on the table surface.
    • This will allow the hinges holding the screen in place to lift up.
  11. While the screen is flat on the surface, slide the bottom half of the computer towards the top of the screen to separate the two halves.
    • While the screen is flat on the surface, slide the bottom half of the computer towards the top of the screen to separate the two halves.
    • The screen is now completely removed from the bottom half of the computer.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Joseph
589 Reputation
6 Anleitungen geschrieben
USF Tampa, Team S20-G1, Passmore Spring 2018 Mitglied von USF Tampa, Team S20-G1, Passmore Spring 2018
USFT-PASSMORE-S18S20G1
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 34
Insgesamt: 339
